Hey, it's Joe with Arizona POCA. In my opinion I have been satisfied with all the modifications to my 72 and have kept the original distributor but replaced the dual points with a Pertronics inductive unit. My problem is finding replacement rotors that fit. Every time I go to a parts counter, they want to sell me a rotor that has a base that is at least 1/2 inch too long. After shaving it to fit, and 1000 miles later the electrode of the Chinese part loosens and looks compleatly unreliable. The steadfast 351 hasn't let me down. I took one off a year ago and it wiggled around with 2 millimeters of play and the motor still ran.
Question 1: Did Autolite stop making these and if not, where can I get a dozen of them?
Question 2: Should I stop hanging on to the distributor and buy a $75 remanufactured late 70's electronic distributor with readily available caps and rotors?
I've never liked the idea of the high tech aftermarket units because many can leave you on the side of the road.
Recommendations welcome.
Thanks
Joe
Joe,
With the original dual point distributor the cap and rotor is and should be available at every auto-parts store in the country as a std ford small block ford rotor and cap ?
If you choose to change it to a Ford Duraspark Distributor any application for a Ford 351C-400M-429-460 will fit your motor. Also sold at any Auto-parts store as a remanufactured. Then obviously you would need the coil and module and wiring. I'm sure PI and or NPD have the entire kit and or parts of the kit for an easy swap.
Ron
There's other considerations with an electronic Duraspark: first will it fit your Pantera? On many Panteras of all years, the clearance between a big-cap Duraspark and the firewall is measured in thousandths of an inch- too close to work effectively.
Usual scenario: you find a cap position that barely fits even if the static advance can't be rotated to quite the correct spot. Drive around town for awhile with no trouble.... until one day, for any reason, you jump on the throttle. The engine shifts on the mounts a tiny bit, the cap touches the firewall and pops up, breaking the rotor. Unless you have a spare cap/rotor aboard, its dead-stop-and-tow-truck-time!
Note- the clearance issue can be addressed in a variety of ways, but there is a less-common small diameter Duraspark cap and accessories made. Both the small and the big Duraspark cap came both with an adapter cone and also as a one-piece cap, further confusing things. The caps take different rotors and spark plug wire ends, too....
Duraspark distributors have many advantages over your dual-point distributor- including accepting the centrifugal weights, springs and internal limiters from your points dizzy to change the advance curve from a 460 truck engine to a performance small-block version. Durasparks still use adjustable vacuum advance cannisters. They accept burn-out-proof e-coils in place of your old can-of-oil coil, and the gear fits cast iron 351-C cams.
But depending on what and where your Duraspark 2 distributor came from, it may or may not be a drop-in, clean-hands adaption. I suggest calling your favorite vendor unless you are intimate with the nuances of 351-C dizzy-swaps.
