With the new filter gasket oiled and the engine block flange checked for the old gasket, the ONLY other thing I can think of is if somehow the male threaded fitting in the block has somehow come loose.
Many owners have abandoned Fram filters in recent years in favor of Wix. They are likely still the maker of the NAPA gold filters.
In buying Wix filters, do NOT opt for the 51515R filters. They have a 61 micron screen versus the 21 in the standard 51515. Better flowing, but the R version is intended for race applications with very regular oil changes.
eBay or Amazon will likely be your cheapest source, whatever filter you are using, when you buy them by the case.
  • wix_51515
From IPSCO SS:
The most technically advanced oil filter you can buy
•Consistent filtering across entire filter surface
•Superior ASTMF316 filtration performance
•7 times the flow of comparable paper oil filters
•Magnetic Prefiltering
•Billet aluminum filter case doubles as an oil cooler
•Progressive rate bypass combined with high flow characteristics of the filter media avoids unfiltered oil bypassing the filter during cold startup and high rpm
•No more cutting apart messy paper filters for trapped debris inspection
•Proven in Motorsports, Military and Aerospace applications for years
•No more oily paper filters to the landfills
•May be the last oil filter you'll buy
•"Inspect, Clean, Reuse"
•100% designed and manufactured in the USA
The filter element is made from medical grade, type 304 stainless steel micronic filter cloth to provide unmatched protection against oil contamination and resultant engine damage. A one inch square of this material flows an incredible 1.9 gallons of oil per minute at only 1 PSI pump pressure. The adhesive used in the filter assembly process is good to 600 degrees Fahrenheit, far above normal engine operating temperatures. A super strength nickel-plated neodymium rare earth magnet is installed in the top of the element for magnetic pre-filtering of the oil. The sophisticated bypass is engineered for proper differential pressures and consistent operation, delivering a greater percentage of filtered oil while being very easy to clean. The twist lock design assures positive filter element placement and allows for easy disassembly, inspection and cleaning. The quad-ring gasket doubles the seal between the filter and the engine. Finally, the filter housing is carved out of a solid chunk of 6061T6 billet aluminum, which not only looks trick but aids in dissipating heat.
IPS160-10B (Billet Finish) ................................... $ 159.00
IPS160-10A (Anodized Black Finish) .................. $ 164.00
IPS160-10C (Chrome Finish) .............................. $ 184.00
