Mark, I may have a set of heads and intake for you. I have to check my engine in storage. Since it is assembled and I have never looked at it closely, how do you tell the difference between open vs closed chamber. I can get the part # if you know, or I can take them off. This was a good running engine with low miles since the last rebuild 10-20K max. I will check ASAP. Bruce bruce.vernon@lmco.com
