I can't find the answer to this. How much anit-freeze does the tank hold if it were completely full and what is the recommended level of the tank?
I looked everywhere. Even under the bed? Anybody?
quote:Originally posted by Rob Borruso:
Do you have an air bleed line coming from your radiator back to the swirl tank?
quote:1) the "swirl tank" needs to be filled to capacity all the time. 2) the "overflow tank" needs to NORMALLY be somewhere about 1/2 full cold. That gives it expansion room and refill capacity both equally at 1/2 of it's volume.
PROBABLY what I will do, probably, leave both tanks where they are and just attach a hose line to the hose nipple on the overflow on the "overflow" tank and just run it to a catch can were it is accessible and be done with it? A definite maybe or maybe a probable probability?
quote:Originally posted by JFB #05177:
some more of my thoughts...
with the 14" tank plumbed like picture #2, and the tops of the expansion and swirl at the same elevation, when the pump stops there will be a path so that the water level in a partially filled expansion will equalize with the swirl, thus the level in the swirl will go down and the expansion go up.
If I should go with partially filled configuration, I would try to raise the top of the expansion about 7" above the top of the swirl. thus if I filled the swirl, it will fill the expansion to the same elevation.
the reason for the swirl tank is to remove air from the circulating coolant. taking the seperation of coolant and air farther would be to eleminate any pressurized air and coolant boundary by completely filling the expansion tank like picture #3. with this configuration, the elevation between the swirl and expansion can have both tops the same.
another consideration between the partial filled or the full filled expansion tank would be the rate of pressurizing the coolant as tempertue increases. with a full tank, the pressure quickly goes to the cap rating (15psig shown). If the expansion tank is not filled exactly to the correct level the coolant pressure will not reach cap rating.
I am thinking picture #3 will be my choice
quote:Originally posted by LF - TP 2511:..I"d really like for us to all agree on proper terms for the two tanks....
The radiator air bleed hose...running to the...swirl tank was outlined in Ford TSB #8, article #61. It superseded an earlier TSB that called for that air bleed to leave the radiator and attach to a revised metal under-car coolant tube located at the radiator....Larry
quote:Originally posted by PanteraDoug:,
What is the original location of the factory "expansion tank" in the car? Is the cap 7" higher than the cap on the "swirl tank"?
quote:Originally posted by Bosswrench:
The connection from the rad cap overflow is 1/4" while the connection to the base of the big recovery tank is 1-3/8"...
'Vented' thermostats with two little air bleed holes drilled in them probably make the 8 extra feet of bleed hose from rad to tank superfluous...
..I may need to build a new tank ....to fit where I want it to go.
... because where the overflow tank is located.
It needs to come out from under the screen so I can monitor it properly...
quote:Originally posted by JFB #05177:quote:Originally posted by PanteraDoug:
Back to your query Doug;
is the problem not being able to add coolant to the tank alone with routinely checking the level.
If just verifing coolant is in the tank. would you want to add a level switch and warning lamp?
Or could you see a sight glass installed at the low level
Now IF it is also needing the ability to add coolant reguraly, how about using a windscreen washer bottle and pump with a feed line installed at tank low level and an overflow at tank high level. then occasionaly fille the windscreen bottle and run the pump till coolant drains back
... I am looking to relocate the "overflow tank" and investigating the volume that the substitute needs to be ...
