Lately, I have noticed a couple of posting in regards to painting the ZF. Therefore, I decided to post some pictures of how I painted my ZF. I used PPG Deltron 2000 urethane enamel for the ZF and I powder coated the bellhousing. I powdered the bellhousing because it sees higher temperatures from heat transfer from the engine. Teh Deltron will safely take about 280 degrees F before failure and the Powder coat will stand up to about 400 degrees F before failure.
Images (18)
  • Start
  • Clean1
  • Clean2
  • Clean3
  • RG1
  • RG2
  • RG3
  • RG4
  • Fclean1
  • Fclean2
  • Epoxy1
  • Epoxy2
  • Paint1
  • BHblast
  • BHpowder
  • Finish1
  • Finish2
  • Installed
