Gosh we need to put this to rest. Jon is a great guy. Easy to work with, and on top of his game. I've gotten to the point now, that I've used just about every product he offers in customers cars. Never a single failure. He has sent me 'prototype' electronic items for testing purposes in the field that I find awesome. Some think his items may be over engineered, but would you like that or prefer 'under' engineered, lol. He is a genius, have you looked on Pantera Electronics sight recently? Many new innovative products showing up constantly. Try his turn signal flasher module, changes out in a second, very inexpensive but super wow factor. I like the tone better than the ticking from the factory, plus with an eyeglass screwdriver you adjust how many beats per minute they blink! How about the door lights, another innovative cool item, again very cost effective. Super bright LED & now blinking so someone at night won't ~knock your door down the street~ because of a dim bulb. For under a hundred dollars, you can get three new items that will 'wow' other Pantera owners, they all install in a minute or two. He builds harnesses, correct complete battery cables now available in red/black or blk/blk as factory, he rebuilds gauges, he has a cool temp gauge resistor that is inexpensive and it works! He offers an H2o water temperature sending unit that has been tested to see if it's within values that work great together without having to install the 5ohm 1/2 watt resister as recorded in the factory TSB's. His resister is plug & play, also an inexpensive item. I love his new alternator, surpasses even the PowerMaster single wire I've been selling for years..Guys go have a look at his new offerings
