I have convert my GT5 suspension to ajustable type and notice right side(driver side)coil spring height tread is almost 1.5 inches spacing difference from the left in order level the car. Even before the conversion is already noticeable, but not that obvious. Dear Sir, I am very appreciate if you can help solve this problem. Thank you very much.
From your description, I can't tell if your problem is the front or the rear suspension. However:if you're talking about setting up aftermarket coil-over shocks, my experience has been that they will be all over the map out of the box. Trying to get them adjusted for a consistent ride height and equal wheel-weighting is an all-day job to do correctly, and there is no reason to expect equal spring-seat positions side-to-side, or front-to-back. Do you mean there's 1.5" variation in- and-out, or side-to-side, or front-to-back?
Thanks Jack, for the reply. My problem is the rear suspension. The 1.5" is the tread difference from the Left side. (springe height tread adjustment) Also where can I purchase my GT5 front tires(285x40x15). I have check with 'P'International without success. Also anyone out there can help. Thank You.
There are essentially NO 285-40x 15 tires left in the world. Production stopped about 10 yrs ago, and Pantera & Lambo guys have been scrambling ever since. Many have gone to 17" wheels due the no tires being available. The Swedish DeTomaso Club got Pirelli to make a run of brand new tires in various Pantera and Lamborghini sizes. They are NOT CHEAP! Try their website: www.detomaso.nu (posted on the Forum by Kjell Jansson a week ago)
