Looking for a front hood for my '71 Pantera. I would prefer one with the "Hibachi"grills but would consider any hood fiberglass or steel.
Thanks,
Ron
quote:Originally posted by accobra:
Thats the dimension down the center 50 5/8" sorry sold it to Richard ??? but I do have a CF hood a 1/16 smaller.
Ron
quote:Originally posted by comp2:
I am a bit surprised you are unable to find one though. Can you not find a fiberglass through PMI or anyone else? I got a deck lid. It doesn't fit well and will need a lot of fiberglass work to get it right but I thought they were available.
quote:I'm working with a Co. in Calif that has hood and decklid molds. Presently he sent me both in fiberglass ... I'm going to try them on both my cars and adjust the fit. Then he is going to adjust the molds and produce them in Carbon Fiber with Honeycomb backing. Total wieght 12 lbs as compared to 28lbs.
The down side is bowing I feel the only way to stop it is to add aluminum supports or a Honeycomb backing for strength.
Did you by any chance call Hall at Hall Pantera?
Ron I would love to see how you make the adjustments to your hood or decklid. I have a decklid from PIM but it is short by over an inch on both ends, the hinge mounts don't line up and the fit is not good. It will need a lot of work. I don't really think anyone could build a hood or decklid that will fit all the Panteras. I suspect there is a bit of variance in the coachwork.
quote:Originally posted by r mccall:quote:Originally posted by comp2:
Thanks! This is exactly what I was looking for. Can you take a few measurements from the PI hood for me?
Thanks,
Ron
quote:Joules I;m 100% sure not all the Carbon Fiber is made ONLY IN RENO
quote:Originally posted by Joules5:quote:I'm working with a Co. in Calif that has hood and decklid molds. Presently he sent me both in fiberglass ... I'm going to try them on both my cars and adjust the fit. Then he is going to adjust the molds and produce them in Carbon Fiber with Honeycomb backing. Total wieght 12 lbs as compared to 28lbs.
I thought that most of the Fibergalss/CF products were actually made here in Reno. There's one guy here who lays up for PI, Wilkinson and PPC Reno. Funny thing is that each vendor has his own mold!
With the way these hoods/decklids are laid up they are only an aethestic CF overlay, not structural CF. Until someone makes a structural vacuum formed/autoclaved CF unit the bowing will always be an issue. It will be even more of an issue if your guy hand lays a 12lb CF unit that is air cured, personally I wouldn't touch that. I thought there was a guy in Europe (Sweden, Norway?) that was trying to go the autoclaved route?
