I built a rotisserie for my MGB with the intention to use on a restorable Plantera (when I find another one). I also made a dolly to use for both MGB and Pantera. I made it wide enough to fit my Pantera when I made it for the MGB. The construction of both are quite simple. Both the steel ftm a steel shop in 20-24' lenths (trailer). Pretty cheap when you buy it that way. Cut it up with a HF Chop say and welded with small mig welder. I built it as fast as I could ahave assembled one from a kit. Measurements where made on the fly. Tube for the rotating part a little longer than needed. I'll probably cut that off next time:
