For sale!
Full turbo kit & Engine parts for near complete engine.
The Turbo kit includes about everything needed to take a long block engine and finish it, except for some possible gaskets for misc items. This includes components like the oil pan, Detomaso Wrinkle black Al valve covers, carb with matching bonnet and chrome inlet duct with K&N cone filter, High pressure fuel pump, intake manifold, heavy-duty Stainless Steel exhaust manifold/headers with external waste gate & dialaboost adjustment, full exhaust out to dual glass pack mufflers & chrome tips, and obviously all of the Turbo components and boost gauge. I'm also including the used Arias Pistons & stock rods (deep dish with matching quench zone for use with closed chamber heads to get apx 7.5:1 CR) because they are really not good for any application except an engine with a turbo or supercharger.
If kit sold seperate, $1800 obo.
Engine parts include,(all brand new, most in packages still):
45345-8 Milodon Intake valve Stainless Steel
45365-8 Milodon Exhaust valve Stainless Steel
100-7101 ARP Rocker Stud Kit 7/16" Screw-in Chrome-Moly High Strength
22565 Milodon Oil Pump Drive Shaft Chrome-Moly High Strength
4804-8 Comp Cams Pushrod Guide Plates 3/8" Chrome-Moly
MS-1010 P-10 Clevite77 Main Journal Bearings .010 under sized
SH-710 S Clevite77 Cam Bearings
CB-927 P-10 Clevite77 Connecting rod Bearings
9-3121 Cloyes Cam drive chain & sprockets True roller
154-5604 ARP Main Stud Kit 4-Bolt mains Chrome-Moly High Strength
R-9343 35 Speed-Pro Piston Rings Chrome-Moly by Sealed Power
3818016 Federal Mogul Freeze Plugs Bronze by Sealed Power
42159-32PCS Manley Valve Guide Sleeve Bronze 3/8" valves .407 sleeve OD
22050 Moroso Oil Restrictor Kit
1 PC-716540 Steetdampr Fluid-damper
20-2710 Fel-pro Race Gasket
201811 Fel-pro Oil pan gasket
1228 Fel-pro Intake manifold gasket
M-84AHV Melling Oil Pump High Volume
436 Ram Pressure plate 11" Heavy weight
Used but reconditioned parts, or ready to be reconditioned.
4 bolt main block (std bore, never been bored out)
4V closed chamber heads (bronze valve guides, hardened exhaust seats, machined pedestals for 7/16 rocker studs and guide plates, 3 angle valve job)
351C stock crank with radiused oil passages, machined and ready to go.
asking $1800 obo for all engine parts
Or $3200 obo if all is bought together
Email me for pics.
Thanks
Nate Weber
nathan.weber@lmco.com
