While digging around in my car, I found this little guy where I’m assuming the original mechanical parking brake used to be.
Is this a line lock parking brake that was intended as the substitute for the mechanical lever assembly that was unceremoniously cut out of the car by a previous owner?
If this is the case, then perhaps someone can give a guy who’s only experience with parking brakes has been the lever or foot activated kind some advice as to it’s operation?
