Have a cooling leak. I have changed hose clamps but that didn¨t help. This will occur when engine is warm. Wonder if anyone know if those fittings are pressed in or if they have threads and what "size. /A
Most brass nipples are threaded into Aluminum, look in thru the back of one and you should see a thread ..or take a small wrench and see if they come out easy ... maybe they were hand tight and you needed to dope them up ?
There are no hex nuts on these brass fittings so I would suggest that they are pressed in.Not sure how you will fix that leak unless you can extract them and seal them back in.
Originally posted by SF: There isn´t that mutch space so I prefer to have the new fiitings when I remove the old ones. Does anyone have the email address to PME? Anders
For information The fittings have threads and they where not tihgten enough, I think. They have been changed to ones that are longer. There is now moore leak(crossing fingers...) Thanks Anders
