The Pantera project that I received in February came without poly locks. My roller rockers are Ford SVO A460 1.73. The studs are 7/16. I need to order a set of poly locks. Does anyone know of the correct poly locks for these rockers?
Maybe…. I think they are correct….
https://scorpionracingproducts...ker-arm-nut-polylock
call… 352-512-0800 ask
Thanks Roland. It looks like they come in a long and short size. The short ones are for valve cover clearance issues. Those above look long to me. I have tall valve covers and I am thinking the tall ones are better in my case. However, these are uncharted waters for me.
I just read that the long poly locks are needed for stud girdles. My engine had those and hence the tall valve covers. Stud girdles help when high RPM's are taking place. I am not continuing with the stud girdles and will set the rev limiter at 5900 or so.
I’d just call the manufacturer.
@stevebuchanan posted:Thanks Roland. It looks like they come in a long and short size. The short ones are for valve cover clearance issues. Those above look long to me. I have tall valve covers and I am thinking the tall ones are better in my case. However, these are uncharted waters for me.
Buy with confidence… call 📞
scorpion racing would know what you need.. parts guy at Ford - questionable 🤨
Tel 352-512-0800
I always try to get the stud up into the hex portion as the barrel is very thin and I've had them break at the top of the stud.
