problem i have with my gt5 is front head lights turn on but dont go up.Checked to see if power is going to the motor that lifts the lights up nothing there.Funny enough under hard acceleration they go up.Any ideas anyone? emmanuel
Usually the micro switch is faulty, the one next to the head light motor. When you hit a bump it goes up thats usually the problem provided you have the voltage at the motor.
