I can't help but think transmission gears just don't 'pop' out of gear, IF they have been fully engaged.
IF fully engaged, I fail to see how the minor shift linkage vibrations caused by a worn trunion, and most questionably, by a loose u-joint, can impart enough force to dis-engage a FULLY engaged gear set.
Will someone please school me as to what I am missing?
Confused
All the possible reasons listed to date are correct. But the most likely is misadjusted shift linkage, or a loose or badly adjusted trunnion support. As mentioned, ANYTHING that prevents a full-length move of the shift shaft into or out of the rear mounted shift box will not-quite-fully engage the synchro slider for that gear inside the tranny. Then under high torque, the syncho slider will move backward into neutral.
I've also seen minor wear and/or linkage misadjustment that prevented full gear engagement unless the AFTERMARKET shift gate being used was trimmed to fit a particular Pantera.
