I need a replacement for my ZF pump.
This one has a keyway.
Mine is bent and I think this was the cause of my water pump bearing being knoqcked out.
Does anyone have a spare or knows where I can source one?
I wonder if this is the same type and size as fitted to Panteras?
Any help appreciated.
Thanks.
Phil
79 Longchamp GTS 3061
Phi; the stock Pantera crank & waterpump pulleys are cast steel, quite heavy, the ratios are special to the Pantera and I seriously doubt if they could be bent even in a collision.... broken, but not bent. FWIW, there are custom aluminum pulleys made by March Performance in the U.S and sold by Jegs & Summitt speed shops. I'll bet one of their units wouls fix you right up. Go to Google & look for March Performance's web site.
Thanks for the input guys.
I'll measure tomorrow.
Mine has a keyway made from a slotted insert in the centre of the pulley.
Difficult to see if this has gone oval as there was some play when the engine was running.
I have a steel pulley around 6" dia and have never experienced or seen a bent pulley but whatever is worn I think it assisted in my waterpump bearing failure.
I'll put the measurements up tomorrow.
Thanks.
Phil
