The shuttle valve part of it seems to be old technology.
Yea, may be old, but when clean and free of varnish is WILL do its job. For those not clear on this valve, it is designed to block off fluid movement to one side of the Pantera's split brake system should one side have a major leak of fluid. The functional side will still have full pressure that forces the shuttle valve to move and block the normally open passage for the other (now leaking) side.
It can cause a headache when bleeding brakes if it slides and varnish prevents it from popping back over into its normal center position. Mine did this once, but a few firm pedal strokes got it back where it belonged.
It can be removed and just replaced with fittings, but if you're going to remove it to do that, why not just take it apart, clean out the 30 years of varnish and put it back in?
Brake system safety is something nice to have, eh?
The long brass piece is the shuttle valve. The center detent is for the switch plunger to rest, with the switch normally open. When the valve slides, the switch detent is depressed by the larger diameter of the valve, closing the circuit and turning on the little red light, which on my early 72 is in the dash between the tach and speedo.
