This is a Pantera project that I received in February.  It is a 72 pre-L setup as a GTS with TWM 8 stack EFI.  The computer that came with the EFI was a Haltech ECU from the mid 90's and I am replacing it with Holley Terminator X.  I am glad  to have the wiring installed and the car is now a step closer to installing the engine and ZF.  Here is a description of the components.  1 is the Holley Terminator X harness.  2 is the restored Pantera wiring harness.  3 is the MSD Digital 6 Plus ignition box.  4 is a big MSD ignition coil.  5 is the starter solenoid.  6 is the Holley Terminator X ECU.  7 is the Ford voltage regulator.  8 is the MSD 8920 tach adapter.
  • mceclip0
If the deck lid on the project had not been cut I might have gone back to a carb.  And since the car already had everything like an electric fuel pump, fuel lines, fuel return line, fuel regulator, TPS for the 8 stack, and bung for the O2 sensor, it made the decision easier to continue with EFI.  You can see the deck lid cutout in the photo below.
  • mceclip0
