I may look dumb asking this question but could someone please let me know how to take the spring off this shock. I need to take the spring out to put in shorter spring...Thanks
I found out that if I turn the top of the coilovers counterclockwise, I was able to make room for the spring seat to slide out and in turn the spring can then be removed. Can anyone verify that it's ok to do that...
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
It's okay to do that....the upper spring seat has a cut out th same width as the shock piston so that if the spring is compressed slightly (or the ride height adjustment loosened all the way) the seat can be removed and then the spring slides out. That is how they are designed to be dismantled.
