Does anyone know how much Freon goes in a conversion from R 12 to R 134 with new hoses an compressor? Where exactly is the filter that is supposed to be pulled out to increase flow. Thanks, Vince 6909
Kinda late to respond.... There is a cone shaped strainer @ the evperator where the line connects. I converted mine to 134a I checked the strainer and it was perfectly clean, I left it there. Then I put in about 3 cans.
