Does anyone have any rack and pinion bearings that they are willing to sell? Or can they be cross-referenced to another bearing.  I am in the process of rebuilding my rack and accidently damaged one of the pinion bearings for the steering box. I have already checked with three of the vendors.
Thanks!
Bill
While a part number would be optimal, most of the time you can find a replacement bearing by taking measurements of the outer diameter, inner diameter, and thickness of the bearing.
The measurements would be in millimeters, and if you have a local bearing distributor, they can surely find a match in stock or available to have shipped to them
