I'd start by removing the visors, then the trim piece above the windshield for access. Since such antennas were normally only installed by European dealers, this is the most likely path.
thanks Jack,I just bought my first Pantera two months ago.I never thought I'd have so much fun! right now the antenna is like a weather vain real loose.I'll try your advice tomorrow.
