(2) 285/40-18 Dunlop Sport 8000 tires.
- 27.0" tall
- Section width 11.9" (measured on 11" wide wheels)
A great fit for a non-flared Pantera!!
Height is close to the original �71 Pantera tire height and completely fills the rear wheelwell without the air gaps typical of shorter tires. Also allows proper set-up of forward rake (ride heights) while keeping front/rear tire gaps uniform.
Width fits nicely w/o rubbing - even with aggressive track use. Also, there's a good selection of both single-piece and modular wheels available in 18"x11". (No need to "squeeze" this tire onto a too-narrow rim to make it fit or due to limited wheel selection.)
These are brand new tires, never mounted and still w/original stickers. Price from Tire Rack was $678/pair. Will sell for $300/pair. Located in So Cal. May be able to deliver at POCA Vegas event in April.
See picture at: http://mysite.verizon.net/res0q9zn/id6.html
Dave
detomaso.pantera@verizon.net
(310) 372-9467
