PanteraDoug
Both of mine are right hand thread and since my drives side has had a tendancy to loosen, I wondered if someone had changed the drivers side and used the wrong one. (I have only had the car a few months)I feel better knowing that is not the case and I just need to tigheten the s*** out of it - Thanks.
I guess I now have to ask whether we're talking about front or rear axles. Given the mention of impact gun, I assumed we're talking about the rear axles. Regardless, front axles also use RH and LH threaded nuts. Early spindles have one-time-use nuts that are swedged to stay in place after proper adjustment. I also drilled my front spindles for castle nuts and cotter pins.
I just did front bearings on my Contour. I broke a 1/2" drive 24" Craftsman power wrench taking off the nut.
You may want to use 3/4 drive on the Pantera. You are going to need to use a pipe extension on the power wrench to get into the 350lbs-ft range.
The problem with the air tool wrenches is that you never know for sure what torque the thing is making.
If you use a regular axle nut and Loctite red you won't need to use a Saturn booster rocket to tighten it.
