...Be sure your turning it in the correct direction! The drivers side-Left has the 'left handed' thread, and turns ClockWise to LOOSEN! The passenger side-Right, has the common Right handed thread that loosens when turned CounterClockWise. If your turning the correct way and can move the nut you may need a longer Bar/cheater pipe. OR sometimes you have to add a little heat with a torch...
