got around to refitting the rear lower suspension arms. these bolt to the chassis via two suport brackets that can have c shaped spacers behind them to set up correct suspension alignment. is there a default start point for this process and how can i measure it. the book shows 2 spacers behind each bracket but when i took it all apart i had help and forgot to log where each spacer came from but i only have 5 in total. any idears ?
