I have removed all the shims and washers from the lower A arms, but still have about a 3/16" toe out. Is there any way to adjust/compensate without having to use custom arms?
If the camber is too negative with all of the lower shims removed, then you will need to replace the upper A-arms with the extended version that is available from some of the vendors.
