Could this be something that someone added in the past. Are you sure that this is an original wire? I can see no reason to have a full time live wire around the engine. Most of the Pantera wires had a heavy insulation. If this is an added wire it could have a thin insulation. Check your wires on fuse 12 to see if the same wire is there or if this wire has been spliced in. In later cars, fuse 12 was switched with the ignition and was not live.
