Was able to remove them easily from a 72. (no screws holding these in)...any tips on how to reintall them? Somehow the lip of the rubber gaskets must be lifted over the metal lip of the window frame. Please advise. Thanks
Wrap a string around the seal inside the rear lip. feed the end of the string into the opening. Now, press the window into the opening. Pull the string out to peel back the rubber lip. Presto - window in place.
