I've used osofast's method to drive the bearing out hydraulically. I used soap shavings along with a socket that fit just inside the bearing and it took a few trys to stuff enough soap in there while compacting it, but eventually it compressed against the socket and came out with a few blows to the socket. you can also use an extension and some of the soap will bleed out as you strike it, but keep at it.
I've used this same method and it works well.
