I want to remove my polyurethane a-arm bushes to replace with the softer factory rubber bushes.
The problem is I've never seen a poly bush, I can't even find a picture, so I'm not sure how to remove them. Anybody out there done this and can tell me the best way to get them out please?
I know this sounds odd but some of the roads here are a litte rough and this has led to both front inboard anti-roll/sway bar brackets snapping. The idea is that the softer bushes (I'm doing the sway bar bushes too) will reduce the impact forces on the chassis and stop anything else breaking (including my teeth - ouch!).
