Originally posted by shotgungrooms:
I will be removing front trunk and rear deck lids for painting touch ups,,,
Front trunk,,, Should I remove the bolts from the lid itself or the bolts from the car side ,,,?
Rear lid,,, Remove the bolts or can you pull the pin out ,,, ?
Front: For alignment purposes I'd remove the bolts from the car side.
Rear: Once again, for alignment purposes I'd pull the pin. By the way, I have some SS bolts with nylock nuts that replace the pins. You can have them if you're interested.
