You CAN do it in the car but it is usually messy.
You need to make a brake line for each reservoir exiting port that loops back into the reservoir.
Then pump the brake pedal a couple of times or at least until air bubbles stop coming out of the tubes.
Then reconnect the lines to the front and rear brakes and bleed them as usual.
You bleed the longest line first.
On most cars that is the right side of the car.
If the pedal does not come up now, that means the master is not producing pressure and it is leaking internally and as such should be considered defective.
That is happening more these days since quality control has gone out the window. Products are being built "off shore", which is a generic term for "good luck pal". Wink
Originally posted by RRS1:
Okay thanks. I did see that on Youtube. Basically just recirculate the fluids in the reservoir. I think I'll remove it to protect my brand new carpeting, and paint job.
Best to be safe. The brake fluid will dissolve the paint where it touches it.
Some master cylinders aren't as sensitive to this as others but I've learned to always do it before putting it in the car.
Saves a lot of wasted time often.
I guess what it is doing is priming the pump?
