Doug,
If your problems come and go, it sounds like grounding issues. Have you checked under dash connections and the grounding points that are all around the car, especially on the systems you have trouble with? Connector male/female blocks, especially wiper motor and headlights, are known to get cruddy with age and just need a good cleaning.
Timma's system uses a bunch of extension leads - it is not like Larry Stock's. Plug and play, yes. But not a direct swap using just the stock wiring like Larry's does. Just thought you should know that.
