Does anyone use residual pressure valves in their brake systems. I got 2 with my new Wilwood system and I am having trouble bleeding my system. I understand you need to use them when the master cylinder is lower then the brake calipers. So do I need them? and are they doing more harm then good?
  • IMG_0461
Make sure you have not installed them backwards. Like you said the main reason is for MC which are mounted low. I have also used them in a non boosted system where bore was minimized and stroke was maximized for brake force. In this system the residual pressure valves kept just a little less on my stroke which gave me a just a little more available stroke if you will.
If you have adequate booster and are not using the entire stroke my vote is you probably don't need them.
Did you get your system from Quella?
2511 has Wilwood calipers, aftermarket MC and the two blue RPV's.
I asked Dennis about this years back. He told me he uses them for a reason, but not the height issue.
He said the Wilwood piston seal o-rings are not really o rings, but quad rings - flat on all four sides. He feels they tend to pull the pistons back into their bores more than a true round o-ring. So, to counteract that piston recession, which would result in a somewhat further piston travel, (and thus slower), before full stopping power, he adds the RPV's to hold the pistons closer to the rotor.
I still have them in, and bleeding the brakes doesn't seem to suffer due to their presence.
