I noticed that when following other Panteras, at stop signs when the driver shifts into 1st gear I see the reverse light briefly flash on, then off. Is that normal? Also, today I noticed my reverse lights were staying on no matter where my shifter was. I ended up taking one of the leads off the switch on the ZF, so I could drive it today and not look like a goof ball. Any ideas what's wrong? Thanks
Good solution George! I'd go for that one but my reverse switch had the same symptoms. It began sticking and eventually just stuck open. I disassembled, cleaned and rebuilt it but it is cheaply made and eventually broke again. I ended up just buying a new improved version from Brian Graham, works great!
