I've seen where the lower control arm mounting points have been used, using both points at each corner. The only issue I can see is that the arms have to come down, in, and up. Not the most simple geometry.
It would be good to get a material list from someone who has done it, because if it's a lot heavier than necessary, it will be a pain to move, and if it's too light ...
