Dick, the seals from Cigognani in Italy are good for the interior 'firewall' window and the wings. They are correct with good quality joins on corners and for the wings hold a nice radius around the outboard rear ' corners'. We had to add a thin plastic tube to push the seal away from one side to centre the glass. but as you know hand made cars are all slightly different. Mike
