I have installed a set of Corbeau seats and they barely fit. The top part of the headrest actaully rubs against the top portion of the headliner area just above the door. This makes it so that I cannot adjust/slide the seat forward and I cannot recline the seat at all either. I had to send back several seat brackets to Corbeau before we found one that sort of worked. I still had to do some major shimming and other stuff to get the brackets to work. So don't believe them when they say Yes they have an off the shelf bracket ready made for your Pantera. Hopefully this helps you.
