I have read a few posts about this subject. Like this one:
http://pantera.infopop.cc/eve/...780005144#4780005144
My shifter does not spring back to center from the 4-5 side. It's fine from the R-1 side. I had this problem before and replaced both springs and clips and gaskets on both sides of the input shaft. The problem went away but now it's back. The linkage is not hung up on the firewall and the trunion bearing is lubed and linkage seems to move freely.
Is there something else that can be causing this?
