I just installed the new engine, clutch,pp, throwout bearing etc. When it came apart they're were shims around the top of the bellhousing? This is the problem. With your foot depressing the clutch it won't let you put it in gear it grinds. But if you put it in gear, then start it with your foot on the clutch, it will let out ok and let the car move foward or reverse. I haven't driven it yet, and it hasent run in 26 years. Should the shims be reinstalled or does it need to be driven to loosen everything up?? HELP!
