Greetings all! Hope everyone had a great Christmas Holiday.
I was allowed some some project time (Pantera time) for the Holiday weekend so I finally got around to removing my shock spacers. I removed the first shock and compressed and removed the spring without any problems, but have spent more than 3 hours trying to pry the freakin spacer loose. I've got it to move about 1/8" using screw drivers and hammers. My shocks appear to have been painted over during restoration, would the coat of paint be enough to prohibit the spacer from sliding out? What is the clearance between the spacers and shock? Anyone had this problem?
Regards,
-William
You need a 5 or 6 inch gear seperator and a hydrqulic press.
The rings are going to have debris and also have corrosion from galvanic action.
Don't listen to this, your's must be the only one that is corroded BS. They all are except possibly the ones that are owned by the special people.
These things are cast aluminum and were press fit on the shock new.
WD40 will help but without the gear seperator you might be stuck on them forever.
You can rent a seperator at a NAPA store. You don't even need to buy one but frankly I don't know how to finish the job without a press.
Doug is right (Oooh That hurt to say Wink), mine were corroded on and had 30 years of mud caked behind them.
The key was getting them started enough to be able to break the corrosive bond and then clear all the crap out. They are a pretty tight fit anyway so additional paint on the shock may worsen taking them off. I used lots of heat to swell the Al a little and a narrow wedge to pry them up from the lower seat.
So here's how it went down:
It lasted about 6 hours, it took chisels, presses, cutting tools, torches, plasma cutters, hydrochloric acid, and finally TNT.
Then I woke up and realized it was just a bad dream.
I decided to take the shock to a friend who owns a performance shop, and using a pneumatic hammer, he removed it in less than 3 seconds.
Bada-Boom Bada-Bing, Bada-Bing Bada-BANG!
For those non-Kali folks, here is what it looks like, not pretty. The aluminum corrodes and decomposes into powder where the two metals meet. I used a chisel and hammer to remove the 1/16" of compacted powder on the shock.
Cheers!
Sorry about the bad pictures, all I had was a camera phone at the time.
  • 12-28-07_0812
