Hey guys. I noticed I had lost drivers side running light. No power. Went to fuse box (Hass conversion) and have fuse 3rd from top blown. Dead short as it blows quickly.
Anybody have the panel diagram handy?
My dash lights are also out.
Any tips for rigging a light up to the circuit to tell me when I've found the problem, instead of repeatedly checking with multi-meter?
Thanks
Will
...Replace the Blown fuse with a 12v lightBulb. 'Jiggle' the 'HOT' wire (12 Volts +) Start From the NON-working light, and work towards the fuse bus. when You jiggle the Shorted(to Ground) length of wire; the Light will Blink!(and Dim and Brighten) The light does not blow! It merely, turns On...
