Ended up pulling my signal switch. Looked like it had been pulled apart previously...hmmm wonder if this has been repaired previously? Stripped it down an found the little spring that pulls the lever arms together had popped off. fitted it back and now the switch is working again. Thanks to those that messaged me with contacts which ultimately led me to a fix, hope the spring stays on.
Images (2)
  • 315263805_545975984023083_7825824914588097756_n
  • 314686644_822047355747641_5587903265964965971_n
