Hi All;
I am trying to figure out some electrical problems with my car. When I turn on the signals left or right the Hazard switch light flashes also. When I turn the right signal on the left one also flashes. When I turn on the headlights the signals don't work at all. I did have the speedometer out last week could I have pulled a wire off of something else? Please help this thing is driving me loopy.
Thanks
Hi Guys;
Thanks for your help. I checked all the thing that were recommended to no avail. I was ready to pull the dash out to check the wiring, then I decided to replace the front signal light bulbs that I had recently converted to LED replacements bought online. That corrected the problem right away. The signals work now with the headlights on. The Hazard light in the switch still flashes when I turn on the right signal. I think I will try replacing the Hazard switch to see if that fixes the problem.
Thanks again
