Is there supposed to be a silver switch under the dash, near the rheostat, next to the steering wheel column? The owner's manual does not mention it. If so, anyone know what it supposed to do?
Not as stock. God knows what may have been added by former owners in 38 years, though. You sure its a switch? The speedo odometer reset knob is there for zeroing miles when you gas up....
If your car has/had a power radio antenna, it could be the switch to raise/lower the antenna. That switch would be momentary at each end and center off.
