Simon,
Here's a 75mm PCD to Momo adapter. The only issue is, it uses 6mm bolts for the steering wheel whereas the Ferrero wheel uses 5mm bolts. I solved the problem with 5mm helicoils. Also, the adapter to Momo hub hardware that comes with the adapter is absolute junk. Don't even try to use it!
https://www.ebay.com/itm/162330099022
I can't take credit for finding this adapter. I thank Larry for that!
One currently available splined and tapered hub that I know of is the one manufactured by and sold by Norm at Teamblitz, a Ford Capri specialty vendor
it provides the first building block and requires the appropriate three hole to six hole, three hole to nine hole and other wheel patterns
he also sells just about all the standard brands of steering wheels and can provide the necessary three hole adapters to mate with his splined hub.
IMG_2631
IMG_2629
IMG_0480
this grant adapter is out of production, but the one made by teamblitz is dimensionally the same.
IMG_3239
Images (4)
  • IMG_2631
  • IMG_2629
  • IMG_0480
  • IMG_3239
