Originally posted by daleyracing:
My fans are right up tight on the radiator, so I should move them out about a inch. Is that correct.
Maybe. There are 2 cosiderations Dennis. (1) Is the fan currently mounted to the radiator fins? If so, it would be wise to mount it a better way. The little attaching rods that pass through the core will eventually wear a hole in one of the fins, even if the fan & the hardware on the outside have foam rubber between them and the core. (2) If mounting isn't an issue, then only consider spacing the fan if you are having an issue with the car running hot at low speeds, stop & go, etc. If the car isn't running hot at any time, don't sweat it.
Keep it in the back of your mind, if you run into a situation where it seems the fan isn't cooling the radiator well enough, you could improve things by spacing it from the radiator core. Besides being a good way to mount the fan to the radiator, and a good way to space the fan away from the radiator core, a shroud will also help insure all the air moved by the fan is moving in the way you want it to.
By the way, since I'm mentioning fan shrowds, I would like to explain, the reason I chose two 11" fans instead of one big fan, is that the shroud, having two 11" holes cut out of it, offers very little resistance to air flow. There is very little shroud, it is mostly cut-out.
Originally posted by Joules5:
are you going to go 1 3/4" tubes all the way to the motor?
Yes Julian, 1 3/4" tubes in both directions.
Getting spaced with my friends on the DTBB, George
