I'm in the process of getting my car back together, after about a year of replacing numerous things. I'm putting on new stainless water pipes as well as new hoses and clamps. Question isoes the speedo-cable go under or over the water pipes? When routed under both of them it fits pretty tight. I know it will work either way but I'm tring to avoid problems in the future if I have to service or remove that part or other parts located in that area. As for the vacumm hose, does it route straight up? Another thing, is the trunion bearing a pain to replace once the engine is in? Thanks for any advice given...
