Such a great resource, I've had most  questions answered just reading past post .So thanks . This might be a dumb question but ----- Would driving the car without the  speedometer gear  harm the gearbox , does it hold anything in place ?
On a completely different subject . Does someone have and  would it be possible to get the dimensions  of the passengers side middle kick panel . Thanks
G.
Some members are selective about which forums they read. You may get better response if you ask the second question as a new topic located in the appropriate forum.
Personally I'm confused what you're referring to as the middle kick panel. A picture may help clarify that. It would also be helpful knowing which year of Pantera you're referring to as well.
Thanks  JT
.And re. kick panel Right,,,   Ok   what I'm referring to is if your sitting in the passengers seat , there's a plastic panel that hides the wires and heater stuff behind the center console that would be left of your left leg . I see what you mean about a picture , think I confused myself ? Anyway , I apologize for my lousy  description  . And will post again to different forum , with a pitcher. Thanks for the Quick response .  1973
Oct292018 019
Oct292018 0211
Images (2)
  • Oct292018 019
  • Oct292018 0211
